Tags Settings
This page enables you to define tags that can be added to an incident. You can then use the tags to categorize and search for incidents.
Predefined Tags
Use this section to create tags as well as tag groups to organize them. The tags you create in this section are available to both administrators and non-administrators in the Tag field in the incident details view.
To define a new tag or tag group, select the button.
To require at least one predefined tag on incidents before they can be resolved, select the Is required to resolve an incident option.
User Defined Tags
This section displays the tags created by administrators, along with tags created by non-administrators in the Tag field in the incident details view.
To let non-administrators define new tags in the Incident Details view, select Allow User Defined Tags to Be Created On the Incident Page.
To define a new tag in this section, select the button.
