Operational Intelligence
SOTI XSight Operational Intelligence provides deep insight into the performance of your entire device fleet from a single screen.
View the following topics on pre-configured device analytics and interactive charts:
- Using Operational Intelligence Dashboards
- Creating an Analysis Profile
- Analyzing Smart Battery Condition
- Reporting
You can view information on a group level or for a single device, and you can customize each dashboard to show metrics that are directly relevant to you. Using the cascading, interactive charts, you can isolate devices of interest within a dashboard and identify the root cause of mobile device and app issues. You can also create watchlists to monitor devices and proactively address issues before they become larger problems.
Before you can begin analyzing data, first create an analysis profile (see Creating an Analysis Profile) and then generate and deploy the agent (see Generating the SOTI XSight Agent).
