WiFi Hotspot
The WiFi Hotspot configuration enables you to configure Android Plus devices as an internet AP (access point) or WiFi hotspot.
This feature will allow a certain number of devices (depending upon your device model) to connect to your device via WiFi.
Note: This feature is applicable to only Samsung MDM 2.x and above. Devices connected through WiFi hotspot will use mobile data.
SSID Enter the WiFi hotspot SSID. You must use at least one of the following macros in the SSID field:
  • IMSI (International Mobile Subscriber Identity) Number
  • ESN (Electronic Serial Number for Motorola devices)
  • IMEI (International Mobile Equipment Identity) Number
  • Phone Number
  • IP address of the device
  • Device MAC Address
  • Device Serial Number
  • Enrolled User Principal Name
  • Enrolled User UserName
  • Enrolled User Email
Security Select the security protocol being used on WiFi hotspot network. You can select open, WPA or WPA2.
Password Enter the password for the WiFi hotspot can be set here.
