Add/Edit Profile
Use this tab to enter a name and description for the profile.
Name Enter a unique name for the profile.
Description Enter a description of the profile.
Type Select the Android device type for the profile: Android Plus, Samsung KNOX, or Android Enterprise.
Configurations
Add Opens a menu from which you can select the configuration you want to add to the profile.
Action Opens a menu with options to edit the selected configuration, delete the selected configuration, or delete all configurations.
Packages
Add Opens the Add Package dialog box in which you can select the package you want to add to this profile.
Action Opens a menu with options to delete the selected package, delete all packages, or define package dependencies.
