VPN: NetMotion
The NetMotion VPN profile configuration enables you to configure NetMotion VPN settings for devices.
VPN Name Enter a name for this VPN connection. The name cannot contain spaces or special characters.
VPN Server Hostname/IP Address Enter the hostname or IP address for your VPN server.
Username Enter a username.
You can use the following macros to specify usernames: %ENROLLEDUSER_UPN%, %ENROLLEDUSER_DOMAIN%, %ENROLLEDUSER_USERNAME%.
Domain Enter the domain that authenticates your VPN connection
Authentication
Authentication Select the authentication method that this VPN connection uses.
Password Enter a password that authenticates the connection on the devices.
Identity Certificate Select the identity certificate used to authenticate with the VPN server.
CA Certificate (Samsung KNOX only) Select the identity certificate used to authenticate with the VPN server.
