WiFi
Network Name The name of the network which the device should connect to. This is also the name of the Wireless Policy.
Security Type The security protocol currently being used on the network. You can select WEP, WPA/WPA2, 802.1x Enterprise or None.
Password The password to connect to the network.
Enterprise Settings If 802.1x Enterprise is selected as the security type, click on the text box to open the 802.1x Enterprise settings page. See below for more information on the 802.1x Enterprise settings panel.
802.1x Enterprise Settings
Note: 802.1x WiFi is only supported on certain devices. Check Vendor Compatibility Matrix: 802.1x Enterprise WiFi for supported devices.
When 802.1x Enterprise is selected as the Security type, click on the Enterprise Settings text field to open a pop-up window.
On the Protocols tab, you can select TLS, LEAP, EAP-FAST, TTLS, and/or PEAP.
The Authentication tab has the following options for configuring the 802.1x settings:
Username Enter the user name, or enter a macro used to set the user name.
Password Enter the password for the provided user name.
Use Identity Certificate Select a certificate used to connect to the wireless network.
Only certificates that have been uploaded to SOTI MobiControl appear in this list.
CA Certificate Select a CA certificate used to verify the wireless network connection.
Phase 2 Authentication Select the Phase 2 authentication protocol to use.
Anonymous Identity Enter an externally visible identification for the wireless connection (for TTLS, PEAP, and EAP-FAST only).
When you have finished configuring the 802.1x enterprise settings, click Save and Close to close the pop-up window.
