Phone Calls
The Phone Calls configuration enables you to control which phone numbers a device is able to place outgoing calls to or receive incoming calls from.
The Phone Calls dialog box displays two lists of phone number lists: an Available Controls List and a Selected Controls List. When you first create a list of phone numbers you want to control access to, it is added to the Available Control List. When you want to apply the phone number list to the configuration, you move it to the Selected Controls List.
Available Controls List This is the list of phone number lists that have been created but not yet applied to the configuration. To apply a phone number list, move it from the Available Controls List to the Selected Controls List.
Selected Controls List This is the list of phone number lists that have been applied to the configuration.
New Opens the New Phone Calls dialog box in which you can create a list of phone numbers to which you want to restrict either outgoing or incoming access.
Edit Opens the Edit Phone Calls dialog box in which you can edit the list of phone numbers to which you want to restrict access.
Delete Deletes the selected phone number list. Only phone number lists that are in the Available Controls List can be deleted.
Notify Server When Call Blocked Records all incoming and outgoing blocked calls to the server log.
Notify Device User When Call Blocked Displays a message to the device user when a call from a blocked phone number is received.
