Email: IMAP Account
Connection
Account Name Specify Account Name or Description.
IMAP Prefix Specify IMAP Incoming Server Prefix.
Mail
Email Notification Choose what to do for email notification.
Sync Interval Frequency of synchronization.
Signature String to be used as the signature of the sender.
Common Access Card (CAC) Authentication Use Common Access Card (CAC) for authentication.
Incoming Server
Server IP Address or host name for the email server.
Port The port number of the server.
Use SSL Select this if email server only accepts SSL protected connections.
Accept all SSL certificates Choose whether to accept all certificates sent by server.
User Enter the user name. Supports the following macros: %EnrolledUser_Upn%, %EnrolledUser_Domain%, %EnrolledUser_Username%, %Prompt%.
Authentication Type Select the server authentication method.
Password Enter the password associated with the user entered above.
Email Configuration Enter email address for the device. E.g., bob.smith@mycompany.com. Supports the following macros: %EnrolledUser_Email%, %Prompt%.
Outgoing Server
Security (Samsung KNOX only)
Prevent other email accounts from forwarding through this account The device user will be prevented from using this account to forward emails.
