Vendor Compatibility Matrix: Lockdown
Some device features may not be compatible with all MDM versions. Refer to the table below to see which features are supported by your MDM version.
Feature Name Generic Plus Samsung Signed Amazon Casio DRS Samsung ELM Signed Honeywell HTC Huawei Kyocera Lenovo LG Motorola Panasonic Pidion Sony
Hide Status Bar n/a n/a MDM 3+ n/a n/a n/a MDM 4+ n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a
Disable Status Bar Expansion 2.2+ 2.2+ 2.2+ 2.2+ 2.2+ 2.2+ MDM 4+ 2.2+ 2.2+ 2.2+ 2.2+ 2.2+ 2.2+ 2.2+ 2.2+ 2.2+ 2.2+
Disable Settings Changes n/a n/a MDM 3+ n/a n/a n/a MDM 4+ n/a n/a n/a n/a n/a n/a n/a n/a n/a n/a
