Profile Packages
Packages are containers for applications, scripts or files to be installed on your devices. If you need to send an application to these devices, you must first wrap it in a package that tells SOTI MobiControl how to install the application onto your devices.
For more information about packages and how to create them, see Using Package Studio.
Note: On Android Enterprise Corporate Personal devices, packages are applied to the Work Profile.
