WiFi
| Network Name | The name of the network which the device should connect to. This is also the name of the Wireless Policy. |
| Security Type | The security protocol currently being used on the network. You can select WEP, WPA/WPA2, 802.1x Enterprise or None. |
| Password | The password to connect to the network. |
| Enterprise Settings | If 802.1x Enterprise is selected as the security type, click on the text box to open the 802.1x Enterprise settings page. See below for more information on the 802.1x Enterprise settings panel. |
802.1x Enterprise Settings
Note: 802.1x WiFi is only supported on certain devices. Check Vendor Compatibility Matrix: 802.1x Enterprise WiFi for supported devices.
			When 802.1x Enterprise is selected as the Security type, click on the Enterprise Settings text field to open a pop-up window.
On the Protocols tab, you can select TLS, LEAP, EAP-FAST, TTLS, and/or PEAP.
The Authentication tab has the following options for configuring the 802.1x settings:
| Username | Enter the user name, or enter a macro used to set the user name. |
| Password | Enter the password for the provided user name. |
| Use Identity Certificate | Select a certificate used to connect to the wireless network.
								 Only certificates that have been uploaded to SOTI MobiControl appear in this list.  |
| CA Certificate | Select a CA certificate used to verify the wireless network connection.
| Phase 2 Authentication | Select the Phase 2 authentication protocol to use. |
| Anonymous Identity | Enter an externally visible identification for the wireless connection (for TTLS, PEAP, and EAP-FAST only). |
When you have finished configuring the 802.1x enterprise settings, click Save and Close to close the pop-up window.
