Email: POP3 Account
Connection
| Common Access Card (CAC) Authentication | Use Common Access Card (CAC) for authentication. |
Incoming Server
| Server | IP Address or host name for the email server.
| Port | The port number of the server. |
| Use SSL | Select this if email server only accepts SSL protected connections. |
| Accept all SSL certificates | Choose whether to accept all certificates sent by server. |
Outgoing Server
Security (Samsung KNOX only)
| Prevent other email accounts from forwarding through this account | The device user will be prevented from using this account to forward emails. |
