Single Sign On
KNOX's Single Sign On identity services enables a one-time action of user authentication and authorization to permit access to multiple services and apps within the container, while also reducing exposure risk of security credentials during logins.
Note: Single Sign On is available to apps developed with the Samsung KNOX SSO APIs. To gain access to the APIs a Centrify account must be used.
			| Customer ID | Your customer ID which is provided by Centrify. |
| Company Name | The name of your company. |
| Company Icon | Any custom icon you wish to use. Clicking the image allows you to upload a new image. |
| Apply SSO to | Select All applications within container to enable SSO on all applications that support the functionality.
								 Select Only specific applications within container to allow you to specify which applications will use SSO functionality. Click Add to enter the name of the application you want to add. This field queries the Google Play store so you can search any application that is available on the Play Store. Click Edit to change the package name and any other information of an application that was already added. Click Delete to remove any applications that have been added.  |
