							| Display Name of APN |
							Enter a name for the APN that is displayed on the device. |
							| Access Point Name (APN) |
							Enter the name or web address of the access point provided by your wireless carrier. |
							| Mobile Country Code (MCC) |
							Select the three digit code, as defined by the ITU, that identifies the network's country of origin. |
							| Mobile Network Code (MNC) |
							Select the mobile network code. The list contains all available mobile networks in the selected country. |
							| Access Point Type |
							Select the access point type. |
							| Access Point Custom Type |
							Enter the custom access point type. |
							| Default Connection |
							Select this option to make this the default APN connection for devices. |
							| Roaming |
							Specify whether the connection should be activated when the device is roaming. |
							| SIM Card ICCD |
							Specify the SIM Integrated Circuit Card ID (ICCID) that services this connection. Use this option with dual-SIM card devices to determine which SIM card will be used for the APN connection. |
		Server
							| Access Point Connection Username |
							Enter the APN username provided by your wireless carrier. |
							| Access Point Connection Password |
							Enter the APN password provided by your wireless carrier. |
							| Server Address |
							Enter the hostname or IP address of the server provided by your wireless carrier. |
							| Port |
							Enter the port number of the server. |
							| Type |
							Select the proxy type. |
							| Server |
							Enter the name of the proxy server. |
							| Port |
							Enter the port number of the proxy server. |
							| Bypass Local |
							Select this option to enable the proxy to be bypassed when local hosts are accessed by the device. |
							| Exception |
							Enter a list of external hosts which should bypass the proxy when accessed. The exception list is a semicolon delimited list of host names. |
							| Enable |
							Select this option to enable the proxy. |
							| Qualified Proxy Server Address |
							Enter the hostname or IP address of the proxy server. |
							| Qualified Proxy Server Port |
							| Port |
							| MMS Proxy Server Address |
							Enter the MMS proxy server address provided by your wireless carrier. |
							| MMS Server Address |
							Enter the MMS server address provided by your wireless carrier. |
							| Port |
							Enter the MMS server port number provided by your wireless carrier. |
							| Authentication Type |
							Select the type of authentication used for the APN connection. |
							| Username |
							| Password |
