Parameter Thresholds
The following settings are on the Watchlist tab of the Analysis Profile setup wizard. Use them to control when to send alert notifications for each device.
Parameter Description
Battery Discharge Rate Per Hour Exceeds Devices whose battery discharge rate per hour exceeds the set threshold
Data Consumed Per Month Exceeds Devices whose total data consumed per month exceeds the set threshold
Memory Consumed Exceeds Devices whose total memory consumed exceeds the set threshold
Storage Consumed Exceeds Devices whose total storage used exceeds the set threshold
Last Virus Scan Exceeds
Devices that have not had a virus scan within the set time duration
Note: This applies to Android devices only.
Last Check-In Exceeds Devices that have not checked in within the set time duration
Last Location Reported Exceeds Devices that have not reported their location within the set time duration
Drop Events Exceeds Devices that have detected and reported device drop events exceeding the set threshold over a number of days as set for the parameter In the Span Of.
