Configure Folder and File Fetch List
Use this dialog box to specify the list of files and folders that will be automatically downloaded to devices.
Files and folders are downloaded to devices in the order in which they appear in the list.
New Opens the Add Path dialog box in which you can specify the file or folder path you want to add to the list.
Edit Opens the Edit Path dialog box in which you can edit the path for the selected file or folder.
Move Up Moves the selected file or folder up one position in the list.
Move Down Moves the selected file or folder down one position in the list.
Delete Deletes the selected file or folder from the list.
Delete All Deletes all files and folders from the list.
