WiFi Hotspot
The WiFi Hotspot configuration enables you to configure Android Plus devices as an internet AP (access point) or WiFi hotspot when:
This feature will allow a certain number of devices (depending upon your device model) to connect to your device via WiFi.
Note: This feature is applicable only to Samsung MDM 2.x and above. Devices connected through WiFi hotspot will use mobile data.
| SSID | Enter the WiFi hotspot SSID. You must use at least one of the following macros in the SSID field:
| Security | Select the security protocol being used on WiFi hotspot network. You can select open, WPA or WPA2. |
| Password | Enter the password for the WiFi hotspot can be set here. |
