Add Buttons
The Add Buttons dialog box enables you to change the default behavior when a button is pressed on the device. You can either redirect a button's action to a specified application, or block the button action altogether.
Lockdown
Use the Lockdown tab to disable particular actions on specified buttons.
| Button Name | Select which hardware button is to be configured. |
| Action | Select an action pertaining to the selected button. |
Remap
Use the Remap tab to remap a selected button's action to launch a specified application.
| Application Type | Select First-Party to select an application that is part of Windows Phone, or Third-Party to select a application that was deployed by your organization. |
| Application Name (First-Party Application) | Select the first-party application to which you want the selected button action to be remapped. |
| Application ID (Third-Party Application) | Enter the ID of the third-party application to which you want the selected button action to be remapped. |
| Parameters | If the application requires any additional parameters, enter them here. |
