VPN: Junos
Configure Junos Pulse VPN settings on your devices.
Network
| Custom Configuration | Enter any custom configuration settings. |
| Trusted Network Detection | Enable/Disable Trusted Network Detection functionality. The VPN will not connect when the user is on their corporate wireless network where protected resources are directly accessible to the device. DNS Suffix is required in order to detect the corporate wireless network. |
Connection Settings
| Proxy Type | Choose between None or Manual. |
| Proxy Server | The hostname or IP address and port number of the proxy server. |
Advanced
| Applications | Use this section to exclude specific applications from the VPN. |
| Name Space | Use this section to exclude specific namespaces from the VPN |
| Network | Use this section to exclude specific networks from the VPN |
