Vendor Compatibility Matrix: 802.1x Enterprise WiFi
Some device features may not be compatible with all MDM versions. Refer to the table below to see which features are supported by your MDM version.
Feature Name Generic Plus Samsung Signed Amazon Casio DRS Samsung ELM Signed Honeywell HTC Huawei Kyocera Lenovo LG Motorola Panasonic Pidion Sony Unitech Zebra Enterprise
Use Certificate for WiFi EAP 802.1x n/a n/a MDM 2.0 All MDM Plugin n/a MDM 4 MDM Plugin n/a MDM Plugin MDM Plugin MDM Plugin MDM 1.0 MDM 4 MDM Plugin MDM Plugin MDM 7+ MDM Plugin MDM 4 L+
