Application Run Control: Blacklisted Applications
Blacklisted applications are blocked from running on a device. Other non-blacklisted application may run without interference. You can add multiple applications to a blacklist. You can also create multiple blacklists.
Enter a name for your new list then, in the Add an Application Name or Bundle Identifier table, start typing the name of the application or its bundle ID, and SOTI MobiControl provides search results you can choose from. Click Add to add a new row.
You can also import lists in .csv format. In the .csv file, list each application starting with its bundle ID then its name. You can also export lists, making it easy to move lists between SOTI MobiControl instances.
