Add/Edit Profile
Use this tab to enter a name and description for the profile.
Name Enter a unique name for the profile.
Description Enter a description of the profile.
Type Select the Windows Modern device type for the profile: Windows Phone or Windows Desktop.
Configurations
Add Opens a menu from which you can select the configuration you want to add to the profile.
Action Opens a menu with options to edit the selected configuration, delete the selected configuration, or delete all configurations.
Packages
Note: This tab is available only when defining a profile for Windows Desktop devices.
Add Opens the Add Package dialog box in which you can select the package you want to add to this profile.
Action Opens a menu with options to delete the selected package, delete all packages, or define package dependencies.
