Sending Scripts to Devices
Use scripts to execute commands on your devices. You can send scripts to Android Plus, Linux, macOS, Windows Desktop Classic, and Windows Mobile/CE devices.
Note: SOTI MobiControl has several predefined scripts ready for use such as activate connection, show message, and wipe device. You can use one of SOTI MobiControl's predefined scripts or create a custom script. For a full list of available script commands, see Using Script Commands.
To send a script to a device:
Tip: If there is a custom script that you use frequently, consider saving it as a preset.
