| Disable Location Service | Determines the status of Location Services on the device. Applications on the device will be blocked from using Location Services. Choose an option from the dropdown list:
									User Controlled: Device user can switch location services on or off.Enabled: Location services are enabled and device user cannot disable them. Disabled: All location services are disabled and no applications can access location information. Device user cannot enable them. |
							| Restrict Telemetry Data | Determines the amount of diagnostic and usage telemetry data sent to Microsoft. Choose one of the following levels:
									Security: Sends only data required to keep Windows secureBasic: Sends basic data such as device information, app compatibility and usage data and data from the Security levelEnhanced: Sends security and basic data plus additional insights such as how Windows, Windows Server, System Center, and apps are used, how they perform, and advanced reliability dataFull: Sends all data necessary to identify and solve issues plus data from the Security, Basic and Enhanced data levels. Levels are listed in order of least to most data sent. |
