Email: POP3 Account
Account Description
| Send Display Name | Enter the display name for the email sender. |
| User | Enter the user name associated with your Email account. |
| Domain | Enter the domain name associated with the account. |
| Sync The Past | Select the amount of time email will be synced. |
Incoming Server
| Server | Enter the IP address or hostname for the POP3 email server. Note: This field is case sensitive. |
| Port | Enter the incoming (POP3) mail port for the account. 110 is the default port for POP3 |
| Use SSL | This option allows the end user to select whether or not SSL is used for communication with the Email server. |
| Accept All SSL Certificates | Choose whether to accept all certificates sent by server. |
| Authentication Type | Select the type of authentication to be used for this account. (Password is only available) |
| Email Configuration | Enter the Email address associated with your Email account. |
Outgoing Server
| Port | Enter the incoming POP3 mail port for the account. |
| Authentication Type | Select the type of authentication to be used for this account. |
Alternative SMTP
