Tags Settings
This page enables you to define tags that can be added to an incident. You can then use the tags to categorize and search for incidents.
Note: All tags created in both the Predefined Tags section and the User Defined Tags section can be added to incidents, whether you are logged into SOTI XSight as an administrator or not.
Predefined Tags
Use this section to create tags as well as tag groups to organize them. The tags you create in this section are available to both administrators and non-administrators in the Tag field in the incident details view.
To define a new tag or tag group, click the Add button button.
To require the addition of at least one predefined tag to an incident before the incident can be resolved, select the Is required to resolve an incident option.
User Defined Tags
This section displays the tags that have been created here by administrators, as well as tags that have been created by non-administrators in the Tag field in the incident details view.
To enable non-administrators to define new tags in the incident details view, select the Allow User Defined Tags to Be Created On the Incident Page option.
To define a new tag in this section, click the Add button button.
