Deleting a Microsoft Exchange Server
Remove all references to the Microsoft Exchange Server from the SOTI MobiControl instance, including in compliance policies.
Once you delete a Microsoft Exchange server, SOTI MobiControl can no longer manage device access to email for the deleted Exchange Server.
To delete an Exchange Server:
- Open the Global Settings view from the main menu.
 - In the Servers List area, right-click on the email server you want to delete and then select Delete Exchange Server Connection.
 - In the delete confirmation box, select Yes.
SOTI MobiControl can no longer manage device access to email in this Exchange Server. User access resets to the default access specified by the Exchange Server which is usually set to block access by default.
