Setting up a Printer Administration Server
Decide whether to install the Printer Administration Server (PAS) interface on the same server as SOTI MobiControl or a separate server. Installing PAS on the same server as SOTI MobiControl enables for an easier setup and decreases the chance of connection issues between the PAS and deployment server extensions.
The Printer Administration Server (PAS) establishes an SSL connection between SOTI MobiControl and Zebra wireless printers allowing SOTI MobiControl to manage the printers.
Use this procedure to do the following actions:
- On the server where you want to set up a PAS, open the SOTI MobiControl console.
- In the SOTI MobiControl console, open the main menu and select .
Select
Add to open the Add Printer Administration
Server wizard.
The Add Printer Administration Server wizard opens and takes you through setting up a PAS. - Enter a name for the PAS and select Create.
Download both the SOTI MobiControl Root Certificate and the
PAS Client Certificate to your server.
Note: Do not close the Printer Administration Server (PAS) dialog box.
- Set a password for the PAS Client Certificate, use it to generate and export a PAS certificate and bind it to the PAS. The password must be at least six characters.
Using the Microsoft Management Console (MMC), install the SOTI MobiControl Root Certificate.
In the Printer Administration Server (PAS) dialog box,
select the link for the PAS installer or go to the SOTI MobiControl Connector page on
the Zebra website.
Note: The Zebra website refers the PAS as SOTI MobiControl Connector. -
At the bottom of the page, select the download link for the SOTI MobiControl Connector.
- On the SOTI MobiControl Connector request page, enter the requested information and select Submit.
- After you have the PAS installer, run it as an administrator on the server where you want the PAS located.
Enter the information requested on the License Agreement
and select Next.
Tip: You may receive errors if your field entries are too long. If you receive errors, replace the values with meaningless, short values such as1. -
Enter the requested information to associate your SOTI MobiControl server with the SOTI connector.
SOTI MobiControl Server Location Enter the location of your SOTI MobiControl server Important: Use the fully qualified domain name (FQDN) and add /mc/pas to the end of the server location path. For example, http://example.corp.soti.net/mc/pas.Only use http, do not use https.
Ensure that the outbound ports 80 and 443 are open on the server where PAS is installed. Unless PAS is on the same server as SOTI MobiControl, open C:\Program Files (x86)\SOTI MobiControl Connector\tomcat\conf\server.xml. Change the port from 443 to another open port. Port 5496 is usually open.
PAS Identity Enter the name you chose for the PAS in the SOTI MobiControl console. SOTI Certificate Select Browse to browse to the location of the PAS client certificate that you downloaded in step 5. SOTI Certificate Password Enter the password you created for the PAS client certificate in step 5. Select Next.
- Select Finish to complete the installation.
- In the SOTI MobiControl console, select OK to close the Printer Administration Server (PAS) dialog box.
You have finished setting up a PAS to manage your printer devices.
What to do next
Connect your Zebra wireless printers to the PAS and enroll in SOTI MobiControl.
