File Sync Scripts
File synchronization scripts enable you to automate actions on the server (before file synchronization) or on the device (before or after file synchronization).
Server Actions
Important: The Server Actions settings are read-only. If you want to add a new server side script (or edit an existing one), Contact SOTI Support for assistance. Existing scripts will continue to work.
		This feature is only available on on-premises instances of SOTI MobiControl.
Device Actions
Specify a script to be run on the device either before or after file synchronization.
| Before file synchronization execute script | Enter a script to be run on the device before file synchronization. To import a previously created script, click the Scripts button. |
| After file synchronization has completed execute script | Enter a script to be run on the device after file synchronization. To import a previously created script, click the Scripts button. |
| Always Execute | Execute the script on the device every time a scheduled file synchronization occurs, even if no files are updated. |
| Only execute if files transmitted | Execute the script on the device only if files are updated by a scheduled file synchronization. |
