Remote Controlling Devices Using SOTI Assist
You must have SOTI Assist installed to use this feature.
  1. Select the device that you want to remote control and click the Remote Control icon in the Device Actions menu bar.
  2. In the Remote Control dialog box, select Web-based and click OK.
SOTI MobiControl will launch SOTI Assist in a new browser tab where the remote control session will begin. See SOTI Assist Help for more information.
