Create/Edit Profile
Use this tab to enter a name and description for the profile. This tab also displays information about the status and version of the profile, the number of configurations and packages it contains, and the device family and type to which it applies.
Configurations
Click the green + button to open a menu from which you can select the configuration you want to add.
Packages
Click Add Package or the green + button to open the Select Packages dialog box in which you can select the packages you want to add to this profile.
Note: Only packages that were created for this profile's platform and that have been uploaded to SOTI MobiControl are listed.
		Note: This tab is available only when defining a profile for Windows Desktop devices.
