Email: IMAP Account
Account Description
| User | Enter the user name associated with your email account. |
| Domain | Enter the domain name associated with the account. |
| Sync The Past | Select the amount of time email will be synced. |
Incoming Server
| Server | Enter the IP address or hostname for the IMAP email server.
| Port | Enter the incoming (IMAP) mail port for the account. 110 is the default port for IMAP |
| Authentication Type | Select the type of authentication to be used for this account. (Password is only available) |
| Re-type Password | Re-type the account password here to verify accuracy. |
| Email Configuration | Enter the email address associated with your email account. |
Outgoing Server
| Port | Enter the incoming IMAP mail port for the account. |
| Authentication Type | Select the type of authentication to be used for this account. |
Alternative SMTP
