Configure Kiosk Mode Settings
Kiosk mode places SOTI Surf in a state of reduced functionality. Device users have limited access to websites and SOTI Surf app settings. The address bar is disabled and users can only navigate forward through hyperlinks and backwards using the back button. The long-press context menu is also disabled.
| Hide App Bottom Bar | When enabled, device users cannot access the bottom bar of the SOTI Surf app, which includes the forward and backward navigation buttons, as well as the home and the app menu icons. Selecting this option causes the Hide App Menu and Clear Cookies with Home options to become automatically selected. |
| Hide App Menu | When enabled, device users cannot access the app menu. |
| Clear Cookies with Home | When enabled, browser cookies are cleared whenever the device user navigates to the home screen. Note: This option is redundant if Disable Cookies is selected in the Configure Privacy Settings dialog box. |
| Disable Keyboard | When enabled, device users cannot display the keyboard, for example when they tap on a text field. Note: Device users will be able to use the keyboard only to log in, after which it becomes disabled. |
