Advanced
Lockdown mode replaces the standard device home screen with a customizable home screen that provides access only to authorized applications and websites. In the Advanced Lockdown Settings you can modify how Lockdown Mode operates on the device.
| Activity Suppression Method: Package Blocking (Legacy) | When enabled, all applications are prevented from launching or running in the background unless explicitly allowed by the active Lockdown policy. This option can be overly restrictive and cause issues by inadvertently blocking system applications. Note: This option should not be used with the Disable Factory Reset and Block OS Upgrade device feature control policies. |
| Activity Suppression Method: Samsung Package Disabling | When enabled, undesired activities are disabled at the package level. This method is only available for certain Samsung devices. The devices must be running Android 5.0+, have MDM5+ and have a 13.3.1+ SOTI MobiControl agent installed. |
