Sending Scripts to Devices
Use scripts to execute commands on your devices. You can send scripts to Android Plus, Linux, Windows Desktop Classic, and Windows Mobile/CE devices.
Note: SOTI MobiControl has several predefined scripts ready for use such as activate connection, show message, and wipe device. You can use one of SOTI MobiControl's predefined scripts or create a custom script. For a full list of available script commands, see Using Script Commands.
			To send a script to a device:
- Select the device or devices you want to send scripts to and click the Send Script icon in the Device Actions menu bar.
				In the Send Script dialog box, enter a script into the Script field by:
				- Selecting a preset script from the list on the left of the dialog box or
- Entering a custom script
- If applicable, click the warning message at the bottom of the dialog box to see which of the selected devices cannot receive scripts and why.
- Click Send Script.
If there is a custom script that you use frequently, consider saving it as a preset.
- Click Create New Script and enter the script in the Script field.
- Click Save Preset and enter a name for the new preset script in Create New Script once it is highlighted green.
- Click Enter.
