Dynamic device relocation allows you to set up rules to move your mobile devices automatically between different virtual groups or device groups in the MobiControl device tree based on the IP address or other custom criteria. This is useful when managing mobile devices in a deployment where the device tree is set up to represent different physical locations (e.g. retail stores, warehouses, regional offices, etc.). In a deployment that has mobile devices connecting from and moving frequently between several different sites, properties or regions, the administrator needs visibility over the movement of mobile devices across different locations. Dynamic device relocation allows the MobiControl device tree to be updated automatically when a device moves to a different location (e.g. a mobile device that has moved from a warehouse or site in Chicago to a site in New York will automatically be relocated in the device tree on reconnection and will appear in the device group for devices in New York based on the new IP address information). Additionally, the devices can also be automatically reconfigured and any modifications to the mobile device settings, specific to the new location, will be sent to the device automatically. The devices are relocated based on the IP address ranges specified for each location. You can also create a custom data identifier which can be the criterion that will be utilized to relocate the devices to the appropriate device group. (Please see the Custom Data page for detailed information on custom data identifiers.)
Create Device Relocation Rule Wizard startup dialog box
Edit Device Relocation Rule dialog box The buttons on the Edit Device Relocation Rule dialog box are explained below:
A relocation mapping can use just the IP address or the custom data entry to specify the relocation rule for mobile devices. If a relocation mapping has both the IP address and custom data entry specified as the criteria, the mobile devices would be relocated only if both these conditions are satisfied. If a device is affected by more than one relocation mapping, the one higher in the list of mappings will have a higher priority and will be effective. You can use the Move Up and Move Down buttons to change the precedence of the relocation mappings if multiple mappings apply to a device.
Device Relocation Mappings dialog box The first two relocation mappings in the previous screenshot have been defined: one is for relocating all devices with IP addresses between 192.168.1.1 and 192.168.1.255 to the Management Devices group and another mapping for relocating all the devices for which the custom data item "Location" has a value of "Region A" to the Warehouses group. Since the relocation mapping with the IP address filter is listed above the mapping with the custom data filter, the IP address mapping will take precedence. If a device satisfies both conditions (e.g. has an IP address 192.168.1.10 and a value "Region A" for "Location"), it will be relocated to the Management Devices group.
Add/Edit Device Relocation Mapping dialog box
The target group is the group, sub-group, or virtual group to which devices will automatically be relocated when connecting to the Deployment Server if the conditions specified in the relocation parameters are met. Multiple relocation parameters can be specified to manage the dynamic relocation of devices. A single parameter can be specified or both parameters can be used for a relocation mapping, in which case the device will be relocated if it satisfies both parameters. The following table describes the fields of the Add/Edit Device Relocation Mapping dialog box:
