The Deployment Server Priority List dialog box allows you to specify the
Deployment Server preferences for the devices. Priority one is the highest and five is
the lowest. When a device is configured with more than one
Deployment Server, it will try to connect to highest priority one first. If this
server is not accessible, then it will try to connect to the next server available.
Multiple servers may be assigned the same priority level to establish a pool of
Deployment Servers to balance the load of a large number of devices.
If you select "Not used," the selected devices will not
connect to that Deployment Server.
Deployment Server priority is only applicable when you have
installed multiple Deployment Servers using the same site name.
