MobiControl provides various
on-device feature controls including the capability to block
various device communications, including what numbers a device is able to call or receive calls from.
Phone Call Policy dialog box
For assistance with Override Settings Click Here.
Phone Call Policy Control Lists
MobiControl allows you to specify the numbers to which users may place calls to
and receive calls from:
Note:
You can't have both deny and allow control lists activated at
the same time. All control lists for a particular direction must be the
same type.
The Available Control Lists displays all control lists that have been defined, but
currently are not in use. IT
administrators are able to create several different phone call policies without having them be
activated on the devices.
The Selected Control Lists displays all currently activated
control lists. Only the control lists included in the selected control
lists are allowed to execute on the
device. This provides an added layer of security for organizations
concerned about unknown phone calls that may be
placed from or received by the device. This can potentially happen without the end user being aware of it, as is frequently the case with viruses, spyware and other malicious applications.
Important:
If the allowed list is not set up correctly, you may end up blocking
or not allowing a potential system critical phone call.
When the Notify Server on Call Blocked check box is checked, the server's
log file will output all calls that were blocked, along with the phone number
that was trying to call in or out for the particular device.
When the Notify User on Call Blocked check box is checked, and the user
receives an incoming call from a phone number that was blocked, a message box
will be displayed
To enable phone call policy control for a device or group of devices, select Phone Call Policy
from the MobiControl Security Center. (Please see the Device Security and Control page.)
New Phone Call Policy entry dialog box
| Field Name |
Description |
| New
Clicking on this button allows you to create a new phone call policy with the dialog box as shown above. Assign a meaningful name to help
distinguish between the various phone call policies you may setup.
| Type
The available options allowed are either Allow or Deny. The type Allow indicates the phone calls that can either be placed from the phone or received
by the phone or both based on Direction set for this policy. The type Deny indicates the phone calls that can not either be placed from the phone or
received by the phone or both based on Direction set for this policy.
If attempting to block restricted or unknown callers simply add <unknown> and/or <restricted> to the deny list. |
| Direction
The available options are Incoming, Outgoing, or Both. Incoming indicates that this policy is for calls received by the device. Outgoing
indicates that this policy is for calls placed by the device. Both indicates that the policy is for both incoming and outgoing calls. For
example, you may want to allow all communication to and from your device to your IT Support team and hence you would select both in this case with the
appropriate phone numbers that can be dialled to work with your support team.
Add Phone Call Policy entry dialog box
Once you have configured the Name, Type and Direction, click on Add... in
order to enter in the phone number(s) that the policy applies to and the dialog
box is displayed above.
MobiControl will compare the number either received or placed with the list of
numbers mentioned in the policy and compare the exact phone number displayed
with the list of numbers you provide. If you have a series of numbers that you would like to enter in,
there are a few options available, which can be used in combination with each
other:
- Leverage the wild card character, which is the asterisk, or '*'.
The asterisk indicates any number of digits. For
example, you may want to only allow calls coming from a particular area code.
In this case, you can enter in '<area code>*' as the number.
Example:
416* would match all calls that start with 416.
- Leverage the single wild card character, which is the question mark, or '?'.
The question mark indicates any single digit.
Example:
You may want to allow communication to a list of phone
numbers that only vary by a single digit. In this case, you can enter in as an
example, 444-555-123?. This indicates the policy applies to the following list
of numbers: 444-555-1230 444-555-1231 444-555-1232 444-555-1233 444-555-1234 444-555-1235 444-555-1236 444-555-1237 444-555-1238 444-555-1239 Combinations of the two wild card characters can also be used if required. For
example, 4??-555-12* would succeed if the phone number is 432-555-1234, but not
if the phone number is 432-432-1234
Import Phone Call Policy entry dialog box
When the Import button is selected, the dialog box above is displayed.
From here you can select any file type. MobiControl assumes that the input file format is one phone number per line.
Example:
905-888-8888
519-222*
416*
Upon reading in the file, the individual numbers will be added to the list control, just as though they were individually typed in using the Add button.
Important:
The file being imported must not contain more than 2000 lines.
