Device lockdown replaces the standard device home screen and Windows Start button with a customizable home screen. Users have access only to authorized applications and websites, and are prevented from accessing all other applications and device controls.
Lockdown Policy dialog box For assistance with Override Settings Click Here. By locking down devices, organizations can minimize the risk of unauthorized persons accessing information on their mobile devices. Administrators can control exactly which programs users are allowed to run, and which websites they are allowed to visit. This decreases the amount of down-time caused by users changing settings that may adversely affect the operation of the device or application software, and also decreases support costs. MobiControl allows running the mobile devices in a kiosk mode with a read-only access to provide critical information to the end users, without giving them access to change the settings. The lockdown menu can only be dismissed by an administrator. Specification of a user password is optional. If not configured the device user can access the lockdown menu directly after turning on the device. If a user password is defined, then the password must be entered in order to access the lockdown menu. To configure lockdown settings for a device or group of devices, select the target device or group in the device tree view in the main console window and select Security from the Configure Device(s) submenu.
Add New Menu Item dialog box
Device Program MenuUse the New button to add menu items. Each entry consists of a user-friendly name and a complete file path to the executable,
On devices that feature a numeric keypad, an alternative to tapping the screen to launch the menu entries is entering the number that corresponds to the
menu item. For example, press 2 to launch the second menu item.
Device lockdown page TemplatesThe lockdown program menu is displayed as an HTML web page to the user. The Template drop-down box allows you to select an HTML template from a list of built in templates and your own customized templates. You can easily create a customized lockdown template by copying an existing template and directly modifying HTML code in the built-in Lockdown Menu Template Editor available in MobiControl. (Please see the Customizing Lockdown Program Menu Templates page.) You can also use your favorite HTML editor. When editing the HTML file, be sure to preserve the special MobiControl Menu tags. These special tags are automatically replaced with the appropriate Program Menu entries by MobiControl. Once you have selected the desired template and clicked the OK button, MobiControl will merge the menu items that you have configured with the selected template and generate a custom HTML menu page.
| Field Name | Description |
| Use custom lockdown navigator | Enabled custom lockdown navigation bar displaying all the available icons This option will only allow the selected icons to show up in a custom navigation bar. The user will have the ability to click on the icons and have view-only access. The user will not be allowed to make any configuration changes using the icons on the navigation bar. Please see the descriptions of the six options following this table.
The icons of the lockdown custom navigation bar are non-responsive on Windows CE 6.0 devices due to a current limitation. This will be addressed in a later version. |
| Use standard operating system navigation bar | ![]() Enabled Windows navigation bar This option will display the standard operating system's navigation bar. This option is recommended if there are specific icons that appear in the standard navigation bar that are not available in the custom navigation bar. In order to prevent the user from accessing Programs listed in the Start menu and links to Settings from popup balloons accessed through the navigation bar icons, the navigation bar is disabled by default. For only Pocket PC devices, it is possible to enable the navigation bar icons. This option will allow the user unrestricted access to the Windows navigation bar. |
| Hide navigation bar | For only Windows CE.NET devices, this option will hide the navigation bar completely. Disabled and enabled "Hide navigation bar" |
The lockdown program menu can be customized a number of different ways. You have the ability to change the lockdown password banner, as well as add your own notification icons. This section will explain how to edit your lockdown using MobiControl Package Studio.
If you would like to add a custom bitmap background image to your password prompt banner and a .bmp file that is 214 by 36 pixels,
it can be added via the authentication policy
If you would like to add a custom notification icons to your lockdown follow the steps outlined below:
The image file must be 16 pixels in height and the width must be an integer multiple of 16. Each multiple of 16 pixels will determine how many icons
are available for use. Now, decide where on the device the image is going to be stored. For example, I have chosen to store it on the device in the
\SOTI\ICONS\ folder. The example image is 48 pixels wide by 16 pixels high, which
will make 3 icons available for display.
Note:
The first pixel in the top left corner of the image will set which color is transparent when the icons are displayed.
Once you have selected the location to store the file, finish the New Package Wizard.
This script will contain different registry settings and commands to install the icon and display it.
First, prepare the registry for the new settings.
regset HKLM\Software\Apps\SOTI\MobiControl LockdownNotificationsregset HKLM\Software\Apps\SOTI\MobiControl\LockdownNotifications 001_IMAGE \
SOTI\ICON\CustIconExample.bmpregset HKLM\Software\Apps\SOTI\MobiControl\LockdownNotifications 001_STATE dword:0
The first line in the script creates a new folder, "LockdownNotifications." The second line creates an entry in the
LockdownNotifications folder called XXX_IMAGE with a value of \
SOTI\ICON\CustIconExample.bmp. This is the location of the image file on the device. The third
line creates a dword value, and this will tell the kiosk which icon in the image to display. Going to the example image
above, when we give a dword value of 0, nothing will be displayed. However, if we give a
dword value of 2 the MobiControl icon will be displayed.
The very first time you create these entries in the registry, or if the image location gets changed, you must restart MCKiosk. This can be done with the script below. It will cause MCKiosk to reload with a delay of half a second:
Start /wait MCKiosk -Quit
Sleepex 500
Start MCKiosk
Now that you have successfully edited the registry, only one registry change is required to switch between the different icons. This is done by using the following command:
dword:#
where "#" is the index of icon you would like. If the number being entered is not valid, no icon will be displayed. When changing
the dword value, the icon will change instantly. This line can be placed anywhere, in any script, to display or change the icon.
Once you finish editing the script, and you are ready to deploy the package to the devices.
Navigation bars with no icon, "Mobi" text custom notification icon, and world custom notification icon
For further assistance, please contact us.
