The Deployment Server Priority List dialog box allows you to specify the Deployment Server preferences for the devices. Priority one is the highest and five is the lowest. When a device is configured with more than one Deployment Server, it will try to connect to highest priority one first. If this server is not accessible, then it will try to connect to the next server available.
Deployment Server Priority List dialog box Multiple servers may be assigned the same priority level to establish a pool of Deployment Servers to balance the load of a large number of devices. If you select "Not used," the selected devices will not connect to that Deployment Server. Deployment Server priority is only applicable when you have installed multiple Deployment Servers using the same site name. Please see the Configuring MobiControl Manager page for more information. |
