The Telecom Expense Management alert rule allows MobiControl administrators to monitor the usage of phone data and voice minutes for a device or group of devices, allowing you to better track data usage within your organization. Administrators can set a threshold (soft, hard, or both), that when breached, activates specified actions regarding the device(s).
If you have not already created a telecommunications plan, select Add New Plan from the dropdown and fill in the fields.
If you do not enable this setting, data usage information is only updated and collected from devices when the MobiControl agent is in the foreground of the device.
Note
The MobiControl agent must have been installed on the device and opened at least once before MobiControl can track data usage.
Select Add New Plan from the Telecom Plan dropdown to open the Telecom Plan Policy dialog. You can create multiple telecom plan profiles to match any plans available within your organization.
You can also update or delete Telecom plans from the same dialog window.
| Setting | Description |
| Select the telecom plan type | Select either Corporate Group Plan or Individual Plan |
| Name | Enter a name for the telecom plan |
| Total Voice (Minutes) | Enter the total number of minutes allotted for the plan. Unlimited is automatically entered if you do not specify a value. |
| Total Data (GB) | Enter the total data amount, in gigabytes, allotted for the plan. Unlimited is automatically entered if you do not specify a value. |
| Start Date | Enter the start date of the billing cycle for the plan |
| Billing Cycle | Choose the period that a billing cycle for this plan covers from the dropdown |
| Description | Enter a description for the telecom plan |
Soft and hard thresholds use the same settings. Think of the soft threshold as a warning and the hard threshold as critical. If data usage exceeds a threshold, the action that you specify is triggered.
Voice and Data Limits
| If Voice Usage on Device Exceeds | Enter a limit for the number of voice minutes that can be used before triggering an associated action.
Note: This option is not available on iOS devices. |
| If Data Usage on Device Exceeds | Enter a limit for the amount of data usage (in GB) that can be used before triggering an associated action. |
You can set multiple actions to apply when a threshold is crossed.
| Relocate Device(s) to | Choose a new device group to relocate your devices to when they exceed a threshold. Use this option for organizational purposes or to apply new (and remove old) device settings. |
| Send Message to Device User | Send a message to the device users notifying them that they have crossed a threshold. |
| Send Email Notification | Generate an automatic email notification whenever a threshold is crossed.
Refer to SMTP Email Profiles for more information on setting up an Email profile. |
Statistics about data usage is collected when the MobiControl agent is in the foreground of the device. Voice usage data is not collected on iOS devices. MobiControl can also collect statistics in background when Location Services is enabled on the device and the device is using a MobiControl SDK-enabled app, and not just the Apple App Store device agent.
You can set data truncation settings to limit the amount of storage space that the data usage information occupies on a device. Devices truncate items that exceed this amount to prevent accumulating an excessive amount of information if they are out of contact for an extended period.
Truncate items based on total size and age.
Usage information collected by MobiControl may not match data usage reports from your telecommunications provider. MobiControl Telecom Expense Management rules are intended only as a supplementary tool to help you track your devices' data usage.
In addition to general abnormalities, the following situations may cause differences between data usage statistics collected from MobiControl and those from your telecommunications provider.
